Realtek ALC883 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1] PCI
pallydo
:confused::confused:
ae se alguem poder me ajudar eu to procurando o driver desta placa acima
c alguem poder responder eu agradeço ;)
galera to precisand d driver d som
tipo o driver é esse o nome + ja baixei varios e n pega
ai vai algumas coisas do pc
a marca é cce
o processador é intel atom 330
Motherboard ID 63-0100-001131-00101111-040609-Lakeport$1AAAA000_RELEASE 04/06/2009
Motherboard Name Unknown
Front Side Bus Properties
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 400 MHz
Effective Clock 400 MHz
Bandwidth 3200 MB/s
Memory Bus Properties
Bus Type DDR2 SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 8:4
Real Clock 800 MHz (DDR)
Effective Clock 1600 MHz
Bandwidth 12800 MB/s
Chipset Bus Properties
Bus Type Intel Direct Media Interface
Device Description
North Bridge: Intel Lakeport-G i945GC
South Bridge: Intel 82801GB ICH7
Field Value
North Bridge Properties
North Bridge Intel Lakeport-G i945GC
Supported FSB Speeds FSB533, FSB800
Supported Memory Types DDR2-400 SDRAM, DDR2-533 SDRAM
Maximum Memory Amount 2 GB
Revision / Stepping 02 / A2
Package Type 1202 Pin FC-BGA
Package Size 3.4 cm x 3.4 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
Memory Timings
CAS Latency (CL) 4T
RAS To CAS Delay (tRCD) 4T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 12T
Row Refresh Cycle Time (tRFC) 34T
Refresh Period (tREF) 3.9 us
Error Correction
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots
DRAM Slot #1 2048 MB (DDR2-800 DDR2 SDRAM)
Integrated Graphics Controller
Graphics Controller Type Intel GMA 950
Graphics Controller Status Enabled
Graphics Frame Buffer Size 8 MB
Chipset Manufacturer
Company Name Intel Corporation
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
Driver Update http://driveragent.com?ref=59
to cm o xp sp3
a marca é cce
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 400 MHz
Bandwidth 3200 MB/s
Bus Type DDR2 SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 8:4
Device Description
Field Value
Core Voltage 1.5 V
Memory Controller
Memory Timings
CAS Latency (CL) 4T
Error Correction
ECC Not Supported
RAID Not Supported
Memory Slots
Salve
bom u andei pesquisando e acabei achando o driver certo,
e como é mei difícil de encontra fiz um Upload no Megaupload
tá ai link
http://www.megaupload.com/?d=9LPIXX45
bom Uso
GM Informatica
ae galera
to com o seguinte problema:
a minha placa de som é onboard o modelo dela é:
Intel 82801g(ich7 family) sm bus controller -27da
já baixei um monte de driver mais nda
eu entro no gerenciador de dispositivos e nda acontece
diz q nao ha drivers instalados para esse dispositivo
o que eu faço^??????
to fikando desesperado já
porque o compuador nao é meu
por favor me ajudem
galera comprei um notebook, veio sem nenhum SO, então instalei o seven ultimate edition 64 bits, ele é um ACER ASPIRE 5732Z, veio um CD com os drivers, intallei todos, menos o da placa de vídeo, porque aparece assim, "Imcompativel com o SO" mas consegui achar na net, porém o PC ta sem som, mesmo com o driver que veio no CD, achei um na net tambem, aparece como se tivesse som, mas nao sai nada, nem na caxinha nem no fone....
alguem sabe o que pode ser?
alem de que videos em alguns sites ficam travando......
por favor alguem me ajuda é horrível ficar sem som....
o driver é o seguinte...Realtek ALC272 @ Intel 82801IB ICH9 - High Definition Audio Controller [A-3] PCI
valeu gente
O meu esta com o mesmo problema!!!!
Informações da máquina:
Computador:
Tipo de Computador ACPI Multiprocessor PC
Sistema operacional Microsoft Windows XP Professional
Placa mãe:
Tipo de processador DualCore Intel Pentium E5300, 2600 MHz (13 x 200)
Nome da Placa Mãe Positivo POS-AG31AP
Chipset da Placa Mãe Intel Bearlake G31
Memória do Sistema [ TRIAL VERSION ]
DIMM1: Positivo Informatica 78.A1GA0.9LM 2 GB DDR2-800 DDR2 SDRAM (5-5-5-18 @ 400 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Positivo Informatica 78.A1GA0.9LM [ TRIAL VERSION ]
Tipo de BIOS AMI (11/25/08)
Porta de comunicação Porta de comunicação (COM1)
Porta de comunicação Porta de impressora ECP (LPT1)
Multimídia:
Adaptador de som Realtek ALC662 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
Armazenamento:
Controladora IDE Intel® ICH7 Family Ultra ATA Storage Controllers - 27DF
Controladora IDE Intel® N10/ICH7 Family Serial ATA Storage Controller - 27C0
Controladora "Storage" AVK55PHS IDE Controller
Disco rígido Generic USB CF Reader USB Device
Disco rígido Generic USB MS Reader USB Device
Disco rígido Generic USB SD Reader USB Device
Disco rígido Generic USB SM Reader USB Device
Disco rígido WDC WD7500AADS-00M2B0 (698 GB, IDE)
Drive óptico HL-DT-ST DVDRAM GH22NS50 (DVD+R9:16x, DVD-R9:12x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM)
Drive óptico XEXQVQX HA3W9EF SCSI CdRom Device
Status dos discos rígidos SMART OK
Se alguem puder me ajudar...Por favor eu realmente agradeceria.!!!!!
c alguem poder responder eu agradeço como faço pra baixar
  • 4 semanas depois...
você pode baixar diretamente do site da INTEl, também, dependendo do modelo de sua placa mãe...
Dj Rayke
gostaria de usar uma boa placa de som para jogar o som do pc no meu HOMER da sony MUTEKY 6.2 Dj rayke você poderia me ajudar a procurar está placa de som posso gastar até R$ 800,00 tem que ser uma placa de video que me entrega 100% de qualidade para o homer . :(
grato
Renato
Dj Rayke
Jovem Dj rayke ,gostaria muito de sua ajuda em relação a placa de som,não consigo obter dos colegas está ajuda ,e se for possivel te peço encarecidamente pela sua copetência que me ajude a escolher uma placa de som 5.1 externa ou interna para meu pc gostaria de ligar está placa no meu HOMER DA SONY MUTEKY 6.1 pode ser uma placa de boa qualidade e que vá atender minhas necessidades com um nivel de qualidade excelente para está placa q você achar ou me indicar ...sou novo aqui no forum e se estou violando algo que não condiz com as regras deste forum minhas sinceras desculpas ..ficaria muito agradecido se puder pelo menos me indicar alguém que pode me ajudar caso você não puder ok..
grato pela sua atenção.
Reanto rocha lozer
estou com problemas de nao sair o som num pc positivo
Tipo de processador DualCore Intel Pentium D 925, 3000 MHz (15 x 200)
Nome da Placa Mãe MSI 945GZM6 (MS-7267 v5.0) (3 PCI, 1 PCI-E Lite, 2 DDR2 DIMM, Audio, Video, Gigabit LAN).
Chipset da Placa Mãe Intel Lakeport-G i945GZ
Adaptador de som Realtek ALC883 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1]
nao tenho o cd d instalacao.
to procurando o driver de som dessa placa.tentei algumas e nao deu certo.podem me ajudar?
som nao sai.
uso windows vista
pc positivo t115sl
realtek alc833
tem saida de som e mic traseiro e frontal,nao funciona nenhuma das 2 .drivers estão instalados.
alguem faz ideia do q fazer?
alguém ai ja conseguiu estalar o driver do som??? eu ja to de cabeça doendo de tanto pesquisar!!!! alguém ai me ajude por favor!!!!Nome da Placa Mãe Gigabyte GA-945GCM-S2L
Realtek ALC662 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1] PCI meu cp e novo!!!! tinha o linux!!!! coloquei o xp agora, e nao quer estalar o driver de som!!!! valeu:confused:
Olha faz o seguinte instala um operating system com drivers prontos e em seguida instala o driver original por cima deve resolver:)
Bily;4281043']estou com problemas de nao sair o som num pc positivo
Tipo de processador DualCore Intel Pentium D 925' date=' 3000 MHz (15 x 200)
Adaptador de som Realtek ALC883 @ Intel 82801GB ICH7 - High Definition Audio Controller [A-1']
vá pra o meu msn [email protected]
talvez eu saiba qual seu problema só preciso de mais informaçoes valeu?
  • 5 semanas depois...
não tenho CD da placa ma~e para instalar os hardwre de som tentei adcionar pelo assistente informa que o arquivo stapi32 dll em IDT High Definition Audio WaveRT Driver é necessario (HARDWARE IDT HIG DEFINITION AUDIO CODEC CODIGO DE ERRO 10) gostaria que alguns de vocês me ajudace a instalar obrigado.
